zapi controller does slowly drive backwards for braking....parameter stay maximum for brake
Hi everyone,
I have a zapi controller 24/300 in a Pimespo but if i drive forwards and i wil brake than i turn backwards( this have not regen brake) and the truck stopping but now he stopping slowly and my brakeway are very longer than first. The battery are 100%.
any idea what this is and how i repair this??
Zapi controller P mos pim SHP 24/300 95310050
mat 6200 0337 FH 2044B
Regards gc_d
  • Posted 13 Aug 2010 04:52
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hi roberto,
Thanks for reply, i go to try this and i hope i find it.
Regards GC_d
If you need Mitsubishi docu. you can ask me
  • Posted 9 Sep 2010 01:29
  • By gc_d
Regards gc_d
Hi gc_d. If the parameters "BRAKING TR" and "IMAX TR" stay at level 9 (you can view/calibrate via Zapi console) I think the problem is on current transducer, follow the step:
1) on cable motor-rotor mesure via hall-ampermeter if the current displaied in menu tester (consolle), is same at the ampermeter? if yes (same) go to step 2, if no (different < 20% or less go to step 3.
2) Check the traction motor effency.
3) Remove the logic board and the down shield, now you can see two shunts fixed by nuts, tighten they with 8mm wrench, repeat step 1 for check verify and test the braking intensity.
Regards RR.
  • Posted 8 Sep 2010 23:06
  • By roberto_r
  • joined 8 Sep'10 - 2 messages
  • VR, Italy
TCM FD115-3
Nagano NUZ090D
TCM FD115-3
Nagano NUZ090D
