yale OS throttle pot calibration?
It is a Yale OS030ben36te119 I replaced failed pot and want to know what the calibration procedure is thanks for any help
  • Posted 9 Mar 2013 05:52
  • By Spec
  • joined 9 Mar'13 - 4 messages
  • Washington, United States
Thanks for that its a new customer so I need to pick up a book on it
I am used to more clark crown and landoll electrics and ic stuff havnt had many Yale/hyster electrics
  • Posted 9 Mar 2013 07:50
  • Modified 9 Mar 2013 07:52 by poster
  • By Spec
get an ohm meter, find the pot center, total value of pot divided in half.
this should be where it is supposed to be unless it has a self centering pot with a detent on the shaft. if it has the self centering pot then yes you will probably have to access the controller and run a calibration mode.
you do know how to access the system dont you?
hold horn button, turn on key and cycle the horn button quickly once, its kinda tricky but if you do it right it will get you in there.
now without a manual to show you the menu structure you'll just be guessing where it is... you'll need that information to find the calibration menu if it has one.
  • Posted 9 Mar 2013 07:10
Terberg YT222
Komatsu FD25T17
RAEDER-VOGEL
Deborah Baker Deborah Baker
