Yale MR16 forklift error codes
Hi, I need some help with fault codes now stopping my forklift working, to give some history the unit has on occasions of powering up, showed a CAN bus error sometimes related to the joystick when power is turned on, which after cycling the power has cleared in the past. Now it won't clear at all and shows a long list of error codes for logic failure and a load of CAN bus errors etc.
Can anyone help please as an email to local Yale repairer has not had a reply, cheers Alan
  • Posted 1 Mar 2018 06:45
  • Discussion started by Barnip
  • Warwickshire, United Kingdom
Olá Roberto
Poderia me passar a lista de erros da yale MR16n
[email address removed]
67984341110
Att
  • Posted 8 Jul 2022 22:46
  • Reply by Cleiton
  • Brazil
Cleiton nova
Same problems to me fault codes is 227-01 equipment not working model (Mr16hd) serial number (D849TO2016m) plz say solutions
  • Posted 14 May 2019 17:31
  • Reply by praveen_m
  • India
S.praveen
MAINI service engineer
6364882643
send me model and complet serial number
i wil send you the complet error list
  • Posted 2 Mar 2018 02:15
  • Reply by roberto
  • para, Brazil
mannes
It's long time since I've seen this question come up, and the info has slowly seeped back into this brain of mine.
First you will need a sappy hand held analizer unit. First all those fault codes you see in the canbus need deleting then start and use the truck
The first code that reappears is where the problem lies, if it points to canbus error then change the canbus, if it says joystick problem then check out the joystick, this joystick has a lot todo reach in and out hoist and lower also the horn is incorporated. The unit is made up with lots of micro mini switches. Anything that small is prone to wear and breakage, the wiring on these trucks is quite reliable I can't ever remember having to repair wiring on these trucks and normally they are quite reliable. If you don't have a zappy diagnostic had held unit, then you may have to get a Yale tech in with his laptop to delete codes.
  • Posted 2 Mar 2018 00:54
  • Reply by NER045
Not really familiar with this model but, if you are seeing stacked Canbus errors you need to do a diagnostic check on the Can loop. If the can loop opens the truck will not finish it's start up sequence. This will cause a continuous string of can errors. Make sure the termination resistors are good also.
  • Posted 1 Mar 2018 08:31
  • Reply by BREWSKI
Hawker Powersource, Inc.
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
JCB 533-105
UN Forklift FBRP15NQZ2
Hoist Liftruck F180-36BOX-CAR
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
edition #1235 - 19 June 2025
