Showing items 1 - 15 of 20 results.
Through service password? Ill look into it tomorrow, thanks!
Any ideas on latest version number, or full serial required?
if your truck has up to date software you can switch between 3-4 lever MLM or joystick via the display
It is a add on to PCST. It is actually a stand alone program.
Would that be done through pc service tool or different?
No jumper available. You can request a new CDF file for three lever only. You will need to get this installed by a Yale tech.
Same issue with number 4, but no 4th lever fitted. Fitting an extra lever clears the fault but an expensive work around, does anyone know if there is a jumper available? If so part number at all?
not sure, but you may need a jumper plug into the 4th lever harness plug.
No 4th lever but I think You can plug one into that board.they can give out all sorts of random code's when they fail.
every thing works fine but it throws an error code up about the 4 mini lever is OORL but there isn't a 4th mini lever fitted and its not turned on through the dash. Its been a strange one.
Not available separate to my knowledge. I've seen them boards fail a couple of times.
There was a problem with the PCB inside of the MLM. Is this available seperately? i can't find a part no. for the PCB, it has got the number 251941A but that isn't recogonised by TVH.
VSM need calibration after settings!
Regards
Petko thank you for the info. I found a setting in the dash options for input device. i couldn't see this option anywere in the manual.It worked straight away. i have got an error code 523249-4 now, some sort of lever 4 input error. i think it is just a parameter needs changing.
VSM need setting and calibration
Regards
