Yale - ERP16ATF E2580
Hi, Fellas I have some troubles in this model(Yale - ERP16ATF E2580)
- Hydraulic system is not OK, display give me [mode4] & Oil sign is activated in screen.
- line contactor coil is so hot in normal operating and i don`t know what the ohm value is it.
thanks for all
  • Posted 9 Jun 2009 06:23
  • By ash_n
  • joined 31 May'09 - 4 messages
  • cairo, Egypt
ashuniversal
Hi ash n,
I thing your truck may be abit short on hydraulic oil and may need topping up.
Mode 4 refer,s to the different take up of acceleration speeds your truck can achieve.
pressing button 1 will give you mode 1 button 2 will be faster still and so on. Its to enable you to make the truck suit the conditions you have to work in
The line contactor has a thermal resistor linked accross the main contact and is the to charge the capacitors in the power unit. It may be the thermal resistor that you have senced getting hot.
Depending on the age of this truck fault codes are shown on the dash display and may be shown as -02 or-56 you need to know what the codes mean to identifye the problem, a modern version of this truck will tell you in the dash exactly what the fault is, ie start switch closed.
Regards Titus
  • Posted 9 Jul 2010 05:08
  • By Titus
  • joined 6 Jul'10 - 185 messages
Taylor T650L
Morooka MFD20
May 14, 2026 - Blair Athol, South Australia, Australia
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
