Yale ERC ERC050ZFN48SE084 and error 41
Model: ERC050ZFN48SE084 type E
s/n: E108V06015U
I received a notice that the forklift can not run and it show error code - 41 and I need to go and see what the problem is.
I suppose that it has SE1000 controller but I'm not sure,if someone can check it based on serial number...?
Tnx in advance
  • Posted 20 Jan 2014 15:26
  • Modified 21 Jan 2014 23:06 by poster
  • By DukeLander
  • joined 16 Jan'14 - 34 messages
  • Vojvodina, Serbia
Thank you for your effort,Swoop!
I'm going today to see the truck,in the meantime I received info that the error code is showing totaly random,sometimes on first start in the morning,sometimes after 5 hours of driving... maybe controler is "dying"...
Tnx to your posts in other topic where you mentioned FSIP,I found there very useful things and probably coop whit them.
  • Posted 22 Jan 2014 13:09
  • By DukeLander
  • Vojvodina, Serbia
AC motor controller on it?
pretty sure its a motor controller overheat code
Status Code 41
Traction Motor Controller Overheat
- Pushing or pulling loads can be a cause for overheating the controller
- Stalling the motor too long
- Not enough heat sink grease between controller and heatsink panel.
- cooling fans not operational (if any are installed)
Make sure on this controller model, there are other trucks in this range that have EV100ZX, SEM controllers and EVT100.
  • Posted 22 Jan 2014 09:10
Highland, IL, United States
Orlando area, United States
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
