Yale 4K lb forklift
It has a Mazda 2.0 eng. It is blowing air out of the air intake instead of ***. I thought it might be a blown head gasket but the oil is in great condition and the fluids are fine. It was running great one day and the next it only turns over. It has full spark to the plugs and coil as well. Propane is making it to the regulator and vaporizer. Air is blowing back through carb and air intake.
  • Posted 19 Dec 2013 04:53
  • By JohnR
  • joined 19 Dec'13 - 4 messages
  • Kansas, United States
Hey John
If you get into the timing belt, for a couple of bucks and an extra 1/2 hour it would be a good time to replace the water pump since it is driven by the same belt.
  • Posted 19 Dec 2013 13:07
  • By BrewCrew
We`re here for a good time
Awesome. I appreciate the advice. I will work on this and get back with you.
  • Posted 19 Dec 2013 08:18
  • By JohnR
If just one or two cylinders are low then the head has to come off whether it's a valve or the gasket. If they're all low then it may have jumped time and I would check the belt and make sure the cam timing is correct before taking the head off.
  • Posted 19 Dec 2013 06:15
Perfect. I just purchased a tester about 30 minutes ago. If I find a cylinder that is below the recommended 120-140 psi what do I do. How do I single the possibility out between valve or head gasket?
  • Posted 19 Dec 2013 05:41
  • By JohnR
I would do a compression check next.
  • Posted 19 Dec 2013 05:32
The rockers are all moving up and down as they should with the valve cover pulled off. Do you know of any good videos sites to show me how to check if the valves are operating correctly?
  • Posted 19 Dec 2013 05:24
  • By JohnR
Sounds like maybe the timing belt broke. You could look under the plastic cover in the front or under the valve cover to see if the camshaft and/or cam gear is turning while cranking the motor.
Edit: maybe you could just look in the oil fill hole.
  • Posted 19 Dec 2013 05:22
  • Modified 19 Dec 2013 05:23 by poster
