Mitsubishi FG20:
Won't start on petrol
Hello
I have a Mitsubishi fge20ct which works both on petrol and lpg forklift next week worked ok I only noticed that when in petrol it took more to start but today while working on lpg I turned it to petrol and I got no starting action starter turns no attempt to fire do anyone have an idea what to look for I will highly appreciate any help
  • Posted 30 Jan 2025 18:48
  • Discussion started by nikosVats
  • Greece
alla about beekeeping
Hi, first thing I would do is check to make sure there is still gasoline in the tank and it did not leak out. Next would be to check if it will run on LP still and only has the issue on Gasoline. I would then check the gasoline fuel pressure to verify that the fuel pump is working and supplying the proper amount of fuel pressure to the engine. If all checks out I would try starting it in Gasoline mode with a can of starting fluid to make sure that there is no ignition or electrical issues when switched to Gasoline mode.
  • Posted 4 Feb 2025 05:47
  • Reply by BFDiesel
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
