Won't power up
Turn key over and distribution board just gives a short beep every 2-3 seconds. Display does not come up. Checked key switch, access 1 connector, all fuses, distribution relay and not finding anything.
  • Posted 3 Feb 2021 04:31
  • By NickN
  • joined 3 Feb'21 - 1 message
What ended up being the issue? Currently having the same problem.
  • Posted 28 Oct 2024 22:56
  • By Mike_Duncan
  • joined 28 Oct'24 - 1 message
Check the emergency disconnect switch.
  • Posted 5 Feb 2021 05:38
  • By Arnie_Sandoval
  • joined 5 Feb'21 - 2 messages
Arnie
Make sure all access modules power connections are snug... had an identical issue on sp4000... turned out to be B- on access 5 loose connection.
  • Posted 4 Feb 2021 10:03
  • By cubapnea
  • joined 3 Apr'13 - 24 messages
If it ain't broken...you know...
Assuming you've verified battery voltage is good, I would start checking CAN wiring
  • Posted 4 Feb 2021 04:46
  • By Triggs
GemOne
GemOne
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Maxlion ESD15M
