wont move
sometimes when I start this lift it will not move for/rev everything else works. Temp is a factor. if the temp is cool 40degrees or less it will not move, if the temp is 80 or so it works 97% of the time.
Seems to be related to ambient air temp.
HELP????
  • Posted 9 Dec 2017 06:19
  • By Bosco
  • joined 9 Dec'17 - 7 messages
Showing items 1 - 19 of 19 results.
i have a crown sp3020 that wont move, any suggestions??
  • Posted 26 Jul 2018 05:34
  • By ellis_z
  • joined 26 Jul'18 - 1 message
I looked through every reach truck, RR5000 through the RM6000....there is no code 309
  • Posted 7 Jan 2018 01:49
  • By Ifixit
good morning sr can you help me my crown series 5200 dont move at all and it show a code 309 but i dont know whats the problem
  • Posted 7 Jan 2018 01:07
  • By bryan_s
  • joined 7 Jan'18 - 1 message
  • New Jersey, United States
bryan
208 means the module did not see it move. Could be encoder or steer module. If encoder you will usually be able tell by watching it on handset if it is module the only way to tell is by swapping it out with known good one
  • Posted 6 Jan 2018 08:37
  • By popeye
Just curious if you have any other ideas?
Thanks for your previous comments as well
  • Posted 6 Jan 2018 02:42
  • By Bosco
Steering motor tries to go back and forth. However it does not move very far. Armature moves 1/2" both ways is about it.
  • Posted 21 Dec 2017 04:54
  • By Bosco
So that means the K5 is supplying the steer module, but it ends there. Remove the brush cover, power it up and see if the motor cycles back and forth
  • Posted 21 Dec 2017 04:14
  • By Ifixit
  • By Ifixit
For some reason I keep thinking it's electrical. But I'm not a tech on these dudes. Handy, but not with this deal. I did watch to see if the steering wheel moves at startup and it does not.
  • Posted 21 Dec 2017 03:57
  • Modified 21 Dec 2017 03:59 by poster
  • By Bosco
If they changed the upper steer bearing, I've never seen the bearings disappear... only the webing in between the **** gets chewed up. The **** collect on one side and wedge the steering. I wish I could put my hands on it... I'm in Pennsylvania
  • Posted 21 Dec 2017 03:53
  • By Ifixit
Ok I took this unit to Lift Solutions in Grand Island, NE (Crown Dealer) They looked it over for roughly 13 hours and decided to change the bearings in the steering drive. I did see the one main bearing they took out and it was missing 1/3 of the ****. I brought the unit home and when I went to start it to move it off the trailer it won't move and displays the wrench. The code is again 208. I talked to the tech and he's going to check with superiors to try and figure out what to do from here. ANY IDEAS out there??
  • Posted 21 Dec 2017 03:46
  • By Bosco
To crown the term gate does not mean the switch it is a simple term for a open circuit, could be the switch but in most cases no.
Swap (move them both to the others spot) the 2 big relays on the distribution board also check the contact behind the cover above the steer module.
  • Posted 17 Dec 2017 09:22
  • Modified 17 Dec 2017 09:24 by poster
  • By Zerk
  • joined 21 Apr'16 - 28 messages
  • Arkansas, United States
When you power up the truck, does the drive unit rock back and forth? If not, then the K5 tips are dirty....(or the floor is preventing it from rocking). But 90% of the time, this code comes from the distribution board connectors. Unplug them all, and plug them back in....that's all you have to do. Crown just released a new replacement connector for those 9 pin mast cable connectors
  • Posted 10 Dec 2017 23:06
  • By Ifixit
K5 relay is the big relay that supplies power for steering. I am talking about the relays on the dist. board that energize with the key switch and gate switches. You also may want to look at the brake module lights behind the drive motor because if it faults you get a gate fault also.
  • Posted 10 Dec 2017 22:42
  • By popeye
Hello Bosco, I checked one Crown manual were said for SP3200 series 208 and 209 are related with steering. I could suggest to check from steering motor ( sometimes the brushes are stuck and when temperature decrease make bad contact with the commutator) check k5 contactor tips and steering controller and connectors. last week I checked one SP and was loose the connection with controller.
  • Posted 10 Dec 2017 17:06
  • By Sparky79cl
  • joined 18 Oct'17 - 11 messages
  • Auckland, New Zealand
The gate switches check out ok and the arms are down. The code it gives is 208 or 209. I don't remember which. But it is the code that might indicate the k5 relay and a couple other things that check ok. Ambient temp is a key. 80 degrees it works fine. 40 degrees it fails 95% of the time.
  • Posted 10 Dec 2017 12:30
  • By Bosco
The gate is when it thinks the gates are up and you are trying to travel and it will not let you. If moving the gates does not help it could be one of the relays on the distribution board. If it is wrench then you need to use the rocker button to see what the fault code is then we can go from there.
  • Posted 10 Dec 2017 12:21
  • By popeye
Yes
The display will sometimes show a wrench or display Gate
  • Posted 9 Dec 2017 23:59
  • By Bosco
Does anything come up on display when it will not move?
  • Posted 9 Dec 2017 22:12
  • By popeye
Muncie, IN, United States
Deborah Baker Deborah Baker
F. Uchiyama
Taylor T650L
JCB 533-105
