Won't move forward or backwards
I am having trouble with a hyster e60xm-33 not moving forward or backwards. I am getting power from thb5 and tb6 from the card. I've checked the diode for a1 contactor and it's good. I can manually move the truck by pushing in all three contacts at the same time so I know the motor is good. Any suggestions on where to go from here?
  • Posted 9 Sep 2022 01:33
  • By Douglas_Porter
  • joined 9 Sep'22 - 1 message
Douglas porter
I believe you are working on a ev100controller if so you need to get a GE hand set and plug in the center port the plug that you take out will control the dash when you plug in you will have no dash display the controller will give you a number like -23 than you can try to fix truck without that it is very difficult it could be any part in the system that can cause that.the six screws that you are testing are just inputs screw 5 and 6are forward and reverse that means your switches are good and wiring to switching to controller but you can't check outputs the hand set will help with this hope l was of some help
  • Posted 2 Oct 2022 08:00
  • By Scott_
  • joined 16 May'21 - 330 messages
Scott
Since the truck will travel when pushing in contacts, I would suspect a problem in the start up sequence. If the hydraulics work then the 1A is pulling in. If they do not, need to verify 1A is working. Other problems can be brake switch, accelerator switch and seat switch. Verify battery voltage before doing anything else. Make sure you do not have any frame voltage higher than 5 volts. Good Luck
  • Posted 1 Oct 2022 00:51
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
SMV (Konecranes) 4632CC5
Terberg YT182
