Won’t lift
I had a friend look at a lift at one time it would only lift a little off the ground.
They clam they blow off a switch under the dash & it work.
And now won't lift. Any advice. Thanks
  • Posted 6 Feb 2022 00:59
  • By Vince_Spera
  • joined 5 Nov'21 - 4 messages
Vince Spera
First do you here the pump coming on when trying to lift if not first l would check my battery truck might be in lift interrupt low battery voltage could not allow to lift check water in cells than take cell reading a good cell should read at 2.1volts per cell put back on charge and see if lifts. Also is there any codes on dash hope this helps
  • Posted 6 Feb 2022 06:46
  • By Scott_
  • joined 16 May'21 - 344 messages
Scott
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Noblelift
