Won't driver or steer.
When I first was called on lift. It just wouldn't steer. it would go forward n reverse. And platform would raise and lower. I got it to steer and moved it back into my shop. It quit once in shop then started operating again.now it will not move forward or reverse and will not steer. Plat form still works. As soon as you step on deadman switch lift beeps and codes out. I have no books or manuals on this lift. I believe that it flashes a code on battery charge level indicator. If this is true it flashes 3 times pauses then flashes 5 times then pauses and flashes quickly(which I imagine is the end of code sequence) serial # on lift is OPX3035005001 model is OPX30.
  • Posted 6 Oct 2015 06:43
  • By twoeey
  • joined 15 May'15 - 49 messages
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
Elwell-Parker ESI500-36
UN Forklift FBRP15NQZ2
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
