Wiring Diagram for Gould GERR18-680TI Battery Charger
Hi All,
We have a Gould GERR18-680TI battery charger and we got a new battery for our lift, but the charger is overcharging it (I assume the amperage is too high), so it starts to boil off the water in the battery and makes a real stink.
I have a local technician who is very good and says he can modify our existing charger to be paired up properly with our new battery and help us save some money by not having to buy a new charger.
If anyone has this information and wouldn't mind sharing it that would be great! It's an old unit, here are the full details of it:
Gould GERR18-680TI
Serial: E 310177
AC IN:
Volts: 208/240/480
A: 20 10
Phase: 3
Hz: 50 60
DC OUT:
Volts: 36
A: 105
Cells: 18
If images would help let me know and I'll send them or post.
  • Posted 27 Jan 2011 09:00
  • By Emgee
  • joined 18 Oct'08 - 1 message
  • Manitoba, Canada
Sounds like the amp hour (AH) rating for the charger is way higher than the AH rating of the battery.
On the charger spec plate you should have an amp hour or AH rating. On the battery, there should be a data sticker or a stamp in the side with a number that looks like this: 18-85-17
We know your charger is 36v so the first group will definitely start with an 18-x-x. We need to fill in the last two blanks.
(the battery number is also stamped into the intercell connector closest to the positive cable. Don't try to look if you don't have experience as you can potentially short out the battery and can get hurt, burned, acid thrown on you, etc... be careful!)
It's simple to figure out though. Using the example above:
18-85-17
18= number of cells X 2 volts per cell = 36 volt battery.
85= Amp hours per positive plate
17= number of plates per cell (each cell has one extra negative plate)
To get the total AH of the battery, multiply the AH per positive plate by the number or positive plates in the cell. So in our example:
17 ÷ 2 - 1 = 8 positive plates.
85 X 8 = 680 amp hour battery
So if you used a 1200AH charger on our example battery it would fry it.
EDIT: I believe your charger is a 680AH charger based on the 680 in the model number.
  • Posted 27 Jan 2011 14:21
  • Modified 27 Jan 2011 14:34 by poster
  • By justinm
www DOT gbcharger DOT com/WiringDiagrams.html
  • Posted 27 Jan 2011 09:56
  • By kevin_t
Try this site they have alot of coverage for diffrent manufacturers and chargers http://www.gbcharger.com/WiringDiagrams.html
  • Posted 27 Jan 2011 09:55
  • By kevin_t
Toyota 8FG25
Terberg YT222
