wiring diagram and service manual MERLO
HY ANITHING KANN HELP MY WITH WIRIANG DIAGRAM AND SERVICE MANUAL FOR MERLO MODEL ROT30.16K SERIAL S.A.V.B 522242
THANKS IN ADVANCE
  • Posted 10 Sep 2013 04:00
  • Discussion started by adi_m
  • romania, Romania
adi
e mail adress metadonul @ hotmail dot com
Hello
I have done susmic12 and the circuit behind dash contact to me if you need them repaired
  • Posted 8 Jun 2020 23:11
  • Reply by markus354
  • Northamptonshire, United Kingdom
Best Regards
How were you able to repair the Sauer Susmic12 box ?
If I open the back of the box, the board is completely sealed with a kind of resin.
Can you explain to me what you did to fix it ?
No indicator leds are on , so I guess there is a serious issue.
Mark
Hi, I also have the same problem: no forward or backward movement. The problem was a bit on/off in the beginning, but now it does not work at all. If I apply power directly to the forward or backward coils on the drive pump it does drive.
I read that it's most probably the onboard computer which is faulty and that it should be fairly easy to fix something on the board. Can anyone tell me how to fix it ? I can't afford a new Sauer Danfoss box, which will cost around €2500 including programming. They should give away these boxes for free as it is clear that these boxes are of a very poor quality.
Mark
please i need wiring diagram for merlo roto 40.18 evs
thank you
  • Posted 14 Mar 2018 21:10
  • Reply by rafaa_a
  • GABES, Tunisia
Hi panayiotis,
I seem to get the same problem on a merlo 35-12.
No forwarding and no backward, I had the +30 connection on board next to steering wheel burned but I repair and it still don't work.
However it work when I engage emergency mode up the left foot.
Would you let me know how you fixe it?
Thank you.
  • Posted 30 Jan 2018 19:12
  • Reply by damien_d
  • Isere, France
Forklift manuals are almost all considered "proprietary information". The only proper place to get them is from your local dealer who is the legal representative of the manufacturer. We all need to respect the intellectual property rights of the copyright holders.
Our Forum Readers can answer specific questions about particular concerns, and even quote small sections of the manuals (it's called "fair use" to intelligently discuss the particular concern), but cannot be seen as trying to get around the rights of the copyright holders (usually the manufacturer).
So if you have a particular problem we are sure there are folks on the Forums here who can give you very well considered opinions about those concerns.
Best wishes
From
Forum Admin
  • Admin
  • Posted 25 May 2016 07:02
  • Reply by Admin
  • Queensland, Australia
Stop asking for service manuals and buy them from the dealer....we do not want to get this forum closed down
  • Posted 25 May 2016 05:45
  • Modified 25 May 2016 07:00 by administrator
  • Reply by lifter01
i would like you to send me the workshop manual please. as far as your problem with forward and reverse you have a problem on pc board that is located right next to your steering wheel. it easy to fix it as long as you know about elecrtronics. i had exactly the same problem and i fix it. the problem was on the board.. thanks again... my email is [email address removed]
  • Posted 24 May 2016 20:04
  • Reply by panayiotis_p
  • 54296, Cyprus
hello , can you send me the wiring diagram and service manual for Merlo at [email address removed]
best regards
about your problem , i need more details, but first you can try to verify the switch forward -reverse and after the direction valve from the hydraulic pump
  • Posted 2 Dec 2015 11:22
  • Reply by cristi_m
  • bacau, Romania
i have the wiring diagram and service manual for merlo roto 4018 EV 1999, which i can send to you if you want, i dont know if it the same as your, but i also have problems on this merlo i just brought from sweden, the engine start alright but no movement both forward and reverse, Can you offer some suggestions for trouble shouting?
SMV (Konecranes) 32-1200C
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
edition #1235 - 19 June 2025
UN Forklift FD50T-NJB3
Taylor T520M
Ottumwa, IA, United States
Harrisburg, SD, United States
Wentzville, MO, United States
