Will not start.
Does any one have any information on the woodward fuel system. Have a unit that will not start unless you remove the orifice mounted on the side of the carb. housing. If you remove the orifice fitting and install a non restricted fitting, unit will run but will backfire through air filter under a load. This has the tier III emission. It has 2 trim valves is there a way to test the trim valves. Regulator was replaced due to the oil build up. I have no information on these units, Thanks. Model#G25P-5 Serial #ML-00805.
  • Posted 25 Apr 2013 14:34
  • By GregM
  • joined 2 Apr'12 - 26 messages
Thanks for the info. the diaphragm in the carb. looks like new. Found a vaccum leak where the carb. mounts to intake, replaced gasket units been running fine. Thanks Again.
  • Posted 13 May 2013 10:46
  • By GregM
sounds like a bad carb. the GM 2.4 had an issue with the tips on the spark plugs coming loose and cause a backfire which damaged the diaphragm in the carb. You can not get a diaphragm, only a complete carb. only way i know to test the trim valves is to use a scan tool and run them. should feel them clicking when it is running. any codes?
  • Posted 12 May 2013 02:16
  • By dale_mc
  • joined 12 May'13 - 12 messages
  • Alberta, Canada
