Will not power up
Ser#A955N01875K unit has a good battery but wen you turn on the key switch it powers up the cooling fans on a check im guessing,, then after that will not do anything i hqve checked the fuse bank the battery has proper volts and im sowing no power to contacter and it shwing a code of 12546 thatsa battery is dead code but the battery checked out. So we pulled a unit off the floor had full charge qnd plugged it into this machine same code showed on display..is there a large 40amp to 300amp fuse some place i cant find any ?
Thank you
Art
  • Posted 26 Apr 2019 02:09
  • By art_t
  • joined 14 Feb'19 - 24 messages
Ok, i have checked the power is getting to the motor controller, the red disks that your talking about are cold to the touch and have no power to that contact once it goes to the motor control box zero coming out..
So? bad controler im guessing??
Thanks Art
  • Posted 26 Apr 2019 20:26
  • By art_t
Ok, will check it out thank you, much appreciated let ya know what i find..
Thanks again.
Art
  • Posted 26 Apr 2019 18:21
  • By art_t
No large fuses in these trucks. Verify voltage is getting through the battery connector. Check the voltage on both sides of the main contactor. Should be about the same, if not check the PTC, that is the orange or red discs that connect to the large cables on the contactor. these allow voltage to keep the capacitors precharged in the motor controllers. They should be warm when you touch them. If this is all good you may have a bad Master controller.
  • Posted 26 Apr 2019 07:27
  • By BREWSKI
Showing code 12576 now,, any help is greatly appreciated..
Thanks Art
  • Posted 26 Apr 2019 02:45
  • By art_t
Lift Tek Elecar
Lift Tek Elecar
Michel Denis Michel Denis
Rail King RK330
JLG G12-55A
