Will not lift
Lift contact will not pull in,tested coil, replaced switch and still does nothing. Everything else is operational. Please help!
  • Posted 24 Oct 2017 22:55
  • By trinidy_c
  • joined 24 Oct'17 - 1 message
  • IN, -
Take the sequence box cover off, there are a few tiny relays under there. Check to see which one pulls in with lift. Then, with battery unplugged, slide a small piece of paper between each relay tip and close it by hand. Sliding the paper out will clean those tips enough for it to work
  • Posted 26 Oct 2017 23:55
  • By Ifixit
More info needed:
-Do you have batt+ and batt- at the coil when lift requested?
-Condition of battery? Charge? Electrolyte? Voltage under load?
-BDI controller working (resetting) properly?
-Do you have tilt pos switches?
-Lockout box... etc... etc...
  • Posted 26 Oct 2017 00:50
  • Modified 26 Oct 2017 00:51 by poster
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
Toyota 8FD45
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
