What is a error code 266 on a Hyster J40XMT2
I cant find an error code 266 on a Hyster J40XMT2
  • Posted 9 Feb 2016 02:38
  • By Gerald
  • joined 9 Feb'16 - 1 message
Hi, having the same problem truck is temperamental moving forward and back. Where are the field cables located?
Thanks
  • Posted 31 May 2024 00:22
  • By Adam_Duff
  • joined 31 May'24 - 1 message
  • United Kingdom
Now it's giving me a 93 code and a 94 code
  • Posted 21 Nov 2017 09:07
  • Modified 21 Nov 2017 09:08 by poster
  • By Buddym
  • joined 21 Nov'17 - 5 messages
You do not need anything to clear the 01 code. Simply sit in the seat. The 99 code requires software access to clear.
  • Posted 21 Nov 2017 07:26
  • By BREWSKI
Ok, how do I clear those codes?
  • Posted 21 Nov 2017 07:05
  • By Buddym
Code 01 is no seat switch input. Code099 is a maintenance reminder. Code 01 you should not be able to move. Code 099 is just a warning code.
  • Posted 21 Nov 2017 06:13
  • By BREWSKI
I am having trouble with my hyster j40xmt, when i turn all the way to the left, it shuts off. I habe two codes on the dash that read -01 and -099, it's also burning up contacts, it also has a light on the dash that has a tire with an arrow, any ideas what it could be?
  • Posted 21 Nov 2017 02:40
  • Modified 21 Nov 2017 02:43 by poster
  • By Buddym
The 2 in front of the code indicates the problem is in the right hand drive circuit. Code 66 is field current exceeds current limit. You need to check the two field cables for shorts to frame and shorts to case. Also check for shorted fields in motor.
  • Posted 9 Feb 2016 03:41
  • By BREWSKI
Libiao Robotics
