What engine do I have?
I got this lift with no paperwork and few factory info plates left on it. It's propane, 4cyl, electronic ignition module, single carb. I need manifold gaskets but don't know if this is a Mazda, GM or Conti.
  • Posted 19 Feb 2009 12:25
  • By wes_m
  • joined 19 Feb'09 - 2 messages
  • Missouri, United States
YOU APPARENTLY HAVE 4 POSSIBILITIES MASDA, ISUZU, GM-153 CU IN, OR GM 181 CU IN. SINCE YOU HAVE NO INFO , CHECK FOR CASTING NUMBERS, OR ELECTRICAL COMPONENTS GM ENGINES WILL HAVE GM OR DELCO STAMPED ON THEM. IF YOU DON'T SEE THESE STAMPS, YOU MAY HAVE ONE OF THE OTHER TWO. BUT WITHOUT THE TRUCK'S SERIAL NUMBER IT'S GONNA BE HARD TO GUESS GOOD LUCK
  • Posted 5 Mar 2009 06:01
  • By OILCAN
  • joined 28 Feb'09 - 10 messages
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
edition #1237 - 3 July 2025
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
East Syracuse, United States
Columbia, SC, United States
Saratoga, United States
