WAVE not turning left
Hello,
I have one WAV50-118 which sometimes throws "steer throttle" error while turning left. Then, sometimes when you pull the steer rocker fully left while driving nothing happens, WAVE just carries on straight. No error.
I've tried to switch the complete left handle from an other WAVE and the problem remains. I could be suspicious about the controller but it's to early. Is there anything else I should check?
  • Posted 2 Feb 2017 04:43
  • By ivanlinaric
  • joined 16 Jan'11 - 110 messages
  • Zagreb, Croatia
Service technician.
Feel free to contact me at ivan.linaric@okretnimoment.hr
This week I went back to the customer to check on this WAVE. No problem they say. Checked for errors; no error. Conclusion: controller fault.
  • Posted 11 Feb 2017 19:15
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
Today I have taken out the NEO motors and blow them with compressed air. There was some brush dust. The brushes are 12 mm, which is OK. Commutator - clean copper. :-)
I have Curtis handset. When operating the rocker from side to side it shows 100% right & 82% left. I have calibrate it a few times. Well, I think I did. I never receive an confirmation from the Curtis handset.
Once, while turning right, WAVE stopped and the handset was showing 100% right from potentiometer.
I've changed the complete left handle again and controller also from another WAVE. The customer will run it for a few days and will see...
Good idea about the castor wheels. I will check that also.
  • Posted 4 Feb 2017 01:54
  • Modified 4 Feb 2017 01:54 by poster
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
Wave drive motors are notorious for problems. I'm not familiar with the the new style neo motors, but the earlier motors were often never cleaned out by the techs, and the brushes were usually not replaced until there was a motor fault code, which by that time it was usually to late and motor damage was done.
That being said, steer throttle fault is a control system problem, not drive system. Do you have the Curtis handset to plug into this machine for diagnostics? If not, you need one, it's very difficult to do good diagnostics on the wave without it. With it you will actually be able to see what's going on with the pots and controller. I'm not sure that you can properly calibrate the pots with out it either.
Just a side thought, have you checked that the front wheels are turning freely?
  • Posted 3 Feb 2017 23:59
  • By fixitandy
  • joined 23 Mar'09 - 81 messages
This industry has a lot of ups and downs
No offence taken. People hire me. :-)
This WAVE has new type NEO motors installed with only a few work hours. I've checked the brushes few weeks ago during service but I will check them again. I've also checked the part of wiring under the platform and it seem alright.
"Steer throttle" error concerns steering potentiometer and it's wiring. This complete circle is inside left handle. But when I change the complete handle from another WAVE the problem remains.
Any other ideas?
  • Posted 3 Feb 2017 00:37
  • Modified 3 Feb 2017 00:39 by poster
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
All the electrical system is isolated from the truck chassis.
As carbon brushes wear down the dust collects inside the motor and over time begins conducting to the chassis causing all sorts of weird things. The wave has dual drive motors and if the one for turning left is "dirty" it could cause this.
If you are not familiar with forklifts it might be best to hire someone. No offence, I have tried assisting people with no repair background before with limited success.
  • Posted 2 Feb 2017 23:50
  • By stam
What do you mean? Example?
  • Posted 2 Feb 2017 22:53
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
Chassis shorts would be a good start.
Motors can ground out.
  • Posted 2 Feb 2017 22:42
  • By stam
SMV (Konecranes) 4632CC5
JCB 533-105
Hyster
