WAVE Battery Replacement?
Hioya team
Quick one I hope. Changing the batteries in the WAVE, is it a straightforward swap out, or is it a bit tricky? Does the system need to be told it has new batteries somehow?
  • Posted 29 Mar 2023 15:33
  • By snowgoose
  • joined 11 Nov'17 - 6 messages
Hello
No worries, I've got part number somewhere for the mod kit if you do decide to fit it, just give me a shout.
I'm only over the ditch, shout loud enough, I'm bound to hear you!!
  • Posted 1 Apr 2023 08:23
  • By Forking_Around
  • joined 17 Jun'21 - 43 messages
  • New Zealand
Many thanks for that, good points cheers, however the batteries are buggered, thanks anyway!
  • Posted 1 Apr 2023 08:15
  • By snowgoose
Hello
Easy replacement job but do you know if this machine has had the BDI mod fitted to it? Issue might not be your batteries, these Wave 50's needed a BDI mod kit fitting as they had issues with BDI readings when batteries were actually ok.
It's an easy mod, just a few relays and a couple of wires from line contactor into can bus system.
I'd be checking that out first before you throw 4 batteries at it, unless you've already load tested them and they are buggered.
  • Posted 1 Apr 2023 06:35
  • By Forking_Around
  • New Zealand
Thankyou!
  • Posted 31 Mar 2023 09:24
  • By snowgoose
Hello
Nope, nothing tricky about it. Just be sure you don't put one in backwards and lift with your legs not your back.
  • Posted 31 Mar 2023 00:21
  • By lumberjack
  • joined 27 Jul'07 - 187 messages
  • Maryland, United States
Terberg RT223
Hangcha CBD15
China
USD1,600
edition #1281 - 14 May 2026
Terberg RT223
Hangcha CBD15
China
USD1,600
