Wave 50 will not lower
Hello
I have big problem. Wave 50-118 will not lower sometimes. The platform locks at different heights.
I have already exchanged:
-solenoid valve
-velocity fuse
I checked connections and buttons. Everything is ok :(
The only hint is that it always happens at low battery voltage.
Does anyone know what is the lowest coil voltage on the solenoid which the solenoid valve will open ?
  • Posted 13 Dec 2018 08:21
  • Modified 26 Dec 2018 17:40 by poster
  • By Dziadzia
  • joined 12 Mar'18 - 13 messages
  • Torowa, Poland
I have a similar problem, did you find the solution?
  • Posted 7 May 2025 05:07
  • By Nemis
  • joined 7 May'25 - 4 messages
  • Mexico
Check the motor cover switch's.
  • Posted 12 Jul 2019 06:24
  • By cesar_c
  • joined 12 Jul'19 - 2 messages
If you can still manually lower the platform after it stops, then the cylinder is ok. Check resistance through the lowering switch. If there is 1 ohm or more, that will give you lower-than-battery volts causing the coil not to work. Pretty sure under 20v....it will not always work
  • Posted 16 Dec 2018 03:40
  • By Ifixit
No Codes :( I'm thinking maybe there is a problem with piston and spring inside the lift cylinder ??
  • Posted 14 Dec 2018 03:26
  • Modified 14 Dec 2018 03:32 by poster
  • By Dziadzia
  • Torowa, Poland
Any fault codes?
  • Posted 14 Dec 2018 03:07
  • By tom_p
  • Alberta, Canada
UN Forklift FGL18T
UN Forklift FB25N1QZ1
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
UN Forklift FGL18T
