WAV60-118 Error Codes 430 352 233
Hello,
2018 WAV60-118 shows fault codes 430 352 233.
What do they mean ?
Thanks
  • Posted 12 Feb 2025 04:40
  • By Judokusq
  • joined 6 Nov'21 - 3 messages
  • Germany
Code 233 directs you to code 430: Missmatch between the str-cmd inputs.
Go to analyzer menu A4.22. Record the voltsge for full left, full right, and neutral. Go to A4.23 record the record the RPM for the same positions. If the readings don't match then there is a most likely an issue with the wiring for that circuit. If they do match then your access 4 is bad.
With the fact that code 352 does not exist I'm leaning more toward a bad access module.
  • Posted 12 Feb 2025 21:31
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
if you have multiple error codes your mast cables are probably faulty
  • Posted 12 Feb 2025 20:01
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Maxlion FD30
USD1
Maxlion FD30
