Water pump removal
Hey. Hope I've got the correct model; all I know for sure is it's a cushion tire Cat, and it says "50" on the side.
Has a Mitsubishi LP gas engine, with a bad water pump. Seems that some of the bolts retaining the water pump are located BEHIND the timing belt cover. So - must the timing belt cover be completely removed (which would also involve removing the crankshaft pulley)? Otherwise, how do I get access to the hidden bolts?
thanks!
Arden
  • Posted 10 Feb 2007 12:33
  • By arden_h
  • joined 10 Feb'07 - 2 messages
  • Virginia, United States
Thank you for your response!!
I found out a couple days ago just what you are saying here. Much easier than anticipated. Many engines require pullers to remove the crank pulley, but the Mitsibushi engine seems to be very well designed. Actually, the whole lift seems easy to repair. And I did find the model, it's a CG-25.
Thanks again.
Arden
  • Posted 25 Feb 2007 14:26
  • By arden_h
Arden, You will have to romove the covers and the timing belt to replace the waterpump on this engine. We always advise replacing the timing belt at the same time since you have it off anyway. The crankshaft pulley just bolts on with 4 12mm bolts leaving only the timing belt drive spocket on the crankshaft. Goodluck
  • Posted 23 Feb 2007 10:42
  • By dan_selph
  • joined 4 Feb'05 - 5 messages
Taylor TT300
Nagano NUZ090D
November 3-4 2026 - Houston, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
May CapEx Index falls Washington, DC, United States
