Raymond EASI OPC30TT:
View and Clear stored fault codes
Hey everyone,
Working on a Raymond that has a flashing wrench light on the dash. Also, operators claim while lowering the unit stops, alarm sounds and needs to be manually lowered. Unit works good after cycling the key switch. I can access the system and scroll through test inputs and outputs ect. Is there an area in the maint section that I can view and clear fault codes through the dash or does a computer need to be used?
EASI-OPC-30TT
EASI-05-BB36461
Thanks in advance.
  • Posted 25 Apr 2013 07:25
  • Discussion started by Miloslouis
"Freedom of the Road"
WHAT SOLVED THE FH PROBLEM?
  • Posted 15 Jan 2015 01:30
  • Reply by VIPER
  • FLORIDA, United States
Thanks JonG.....I'm swapping it out on Monday. I'll post if the problem is fixed.....thanks again!!
  • Posted 26 Apr 2013 13:52
  • Reply by Miloslouis
Yes, the battery is too low, sounds like a bad battery, the older OPC's were sensative to voltage
  • Posted 26 Apr 2013 13:47
  • Modified 26 Apr 2013 13:48 by poster
  • Reply by JonG
  • United States
Worked on this unit more today. I'm pretty confident that this system doesn't store fault codes. Just displays them when the fault happens. I could be wrong, but I can't find any area in the system that shows any stored fault codes. Got the unit to fail while lowering and travel with fault code FH (battery voltage out of range). But, never while lifting. Did load test the battery earlier this week and today with same results, voltage drop to around 21.4 volts. Checked for shorts to the frame ok and static strap good. Has anyone experienced anything close to this? Bad battery?
  • Posted 26 Apr 2013 10:08
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
KION reports dip in Q1 revenue Frankfurt am Main, Germany
RAEDER-VOGEL
Toyota 8FD35U
Flesherton, Ontario, Canada
Terberg YT182
edition #1229 - 8 May 2025
