veracitor code
I have a code of 522655-1. Any help would be appreciated. Thanks, Jim
  • Posted 12 Apr 2010 23:12
  • By jim_v
  • joined 26 Aug'08 - 61 messages
  • Michigan, United States
DO YOU KNOW WHAT A CODE 524213-1 IS AND ALSO A CODE 177-3. I THINK IS A TRANS TEMP SENDER. BUT WHERE IS THAT LOCATED? THIS IS A HYSTER S80 FORTIS, GM V-6 ENGINE
THANKS FOR ANY INFO.
  • Posted 30 Sep 2010 07:38
  • By TAILLIFT
  • joined 30 Sep'10 - 9 messages
according to my notes i have with the hyster fortis, because realistically their both the same.
the following code you have is: Shot Term Closed Loop Correction Bank ! Greater than NOR40%, which from the notes says it detecting the truck is running lean.
I would start by checking the propane system like the filter, all the wires, ensure no overheating, no exhaust leaks, check the carb....after all that and still
it says that O2 sensor maybe bad.
  • Posted 15 Apr 2010 15:26
  • By CLTL
  • joined 27 Jan'10 - 21 messages
Commercial Lift Truck
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
