unit will power up but no functions
was having down issues after finding chafed harness in scissor arms to platform it tripped the breaker a a few times at the ground box and lost all control functions except down. repaired wires still nothing flashing 6-6 on platform box tried new harness still nothing tested powers and grounds at power module in front of lift everything good there. at the 12 pin conector plugged in 20ohms at pin 10 and 11 and 120 ohms unpluged am i pulling my hair out with this any help would be great
  • Posted 15 Apr 2025 22:22
  • By Marcas_Belanger
  • joined 15 Apr'25 - 2 messages
  • Maine, United States
Ok...do troubleshooting in manual for 661...if everything passes 662...it will tell you what needs replaced for sure
  • Posted 18 Apr 2025 12:16
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Yes I have analyzer. I have tried resetting model number only code I get after everything I try is the 661
  • Posted 17 Apr 2025 19:34
If it's your lift..invest in an analyzer...it will allow for specific codes..and give better options for troubleshooting...try unplugging both drive motors..and then disconnect ground..reconnect after 30 seconds...see if operates up/down from lower controls...if code comes on...then you would normally next use analyzer to change model and country of origin...restart machine..then change back to reset to original setup
  • Posted 17 Apr 2025 13:51
  • By Matthew_Reed
UN Forklift FD35T-C2JB2
Mitsubishi FGE35AT
edition #1302 - 8 October 2026
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
Libiao Robotics
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
March 16-18, 2027 - Stuttgart, Germany
October 26-27, 2026 - Fort Shelby, Michigan, United States
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
