Unit has no spark
I have a S50FT with a Spectrum 2.2 engine that has no spark. I have constant 12VDC on middle wire to coil pack. Am I looking at a bad ECM?
  • Posted 31 Aug 2022 00:41
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Should you still have problems with the spark, you need to verify wire connections from the ECM to the pack. Lift has been known for failed wire harness. Good Luck
  • Posted 1 Oct 2022 00:44
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
Possibly the camshaft position sensor. If you can access the diagnostics in the display, open the page that shows RPM and activate the starter with a remote button, cranking RPM will be displayed. No RPM = bad cam sensor.
  • Posted 14 Sep 2022 07:22
  • By Tinmanxx
  • joined 14 Sep'22 - 2 messages
  • Washington, United States
Pull the spark plug boot from the coil and see if arcing is showing. Remove spark plug and lay it on the valve cover an see if you have spark or ground the threads on the plug.
  • Posted 1 Sep 2022 01:02
  • By grant_c
  • joined 12 Aug'16 - 27 messages
  • Manitoba, Canada
