Yale GLP050VXEURE090:
TRUCK WON'T START WITHOUT CHOKING
YALE FORKLIFT WON'T START WITHOUT CHOKING THE CARB BY HOLDING YOUR HAND OVER THE AIR HORN. ONCE THE UNIT STARTS IT RUNS GREAT. THE ERROR CODE ON THE DASH THAT DISPLAYS IS 524261-3 WHICH IMMEDIATELY CLEARS FROM THE DASH ONCE THE ENGINE STARTS TO RUN.
ANY HELP IN FIGURING OUT THIS ISSUE WOULD BE GREATLY APPRECIATED. WE'VE TESTED AND CHECK THE ENTIRE LP SYSTEM AND WIRING, THROTTLE SENSOR AND ENSURED THAT THERE ARE NO VACCUM LEAKS.
  • Posted 13 Nov 2018 08:53
  • Discussion started by greg_a
  • Illinois, United States
If you follow the hose back from the injector, you will find a round housing with three screws. There is a filter in this housing that can become plugged. If the filter is not plugged than you need to check the lockoff valve on the regulator.
  • Posted 14 Nov 2018 06:28
  • Modified 14 Nov 2018 06:29 by poster
  • Reply by BREWSKI
Brewski, seems as though the injector is not injecting but has 12V at the injector and the VCM like it should. It just never injects fuel. We have put it directly to power and the injector works like you described earlier. Short of determining that the VCM needs to be replaced, is there another circuit, like fuel lock-off, that may be inhibiting the injector from injecting? Or does this sound more like a VCM issue?
  • Posted 14 Nov 2018 04:57
  • Reply by greg_a
I will let you know what we find... thank you so much for all of your direction ---
  • Posted 14 Nov 2018 02:19
  • Reply by greg_a
At the base of the intake manifold, under the mixer there is a electronic injector. It has a plug with 2 wires going to it. Remove the valve from the manifold and hold it in your hand. Turn the key on and you should fell the valve vibrate. There should be a small amount of LP coming out of the valve. If it is not vibrating try cleaning with carb cleaner. If it still doesn't vibrate check to see if there is a voltage across the terminals. If there is a voltage, replace the injector.
  • Posted 14 Nov 2018 01:55
  • Reply by BREWSKI
The serial number of the truck is B875B02525C
  • Posted 14 Nov 2018 01:36
  • Reply by greg_a
You really need a schematic for your truck to diagnose this problem. What is your serial number?
  • Posted 14 Nov 2018 00:32
  • Modified 14 Nov 2018 00:33 by poster
  • Reply by BREWSKI
Depends on which engine and the vintage of the truck. The two you need to check are probably at pin 19 and pin 49 on the ECU. C is not on all trucks.
  • Posted 14 Nov 2018 00:29
  • Reply by BREWSKI
Thanks Brewski - looking for a bit more information on the 5V "A", "B' and "C" supply. More to the point, where are they?
  • Posted 13 Nov 2018 23:50
  • Reply by greg_a
524261-3
A. 5 VOLT "A" SUPPLY SHORTED TO BATTERY SOURCE
B. 5 VOLT "B" SUPPLY SHORTED TO BATTERY SOURCE
C. 5 VOLT "C" SUPPLY SHORTED TO BATTERY SOURCE
D. VSM FAILURE
E. 5-VOLT SUPPLY SHORTED TO BATTERY SOURCE
F. FUNCTIONAL FAILURE IN CONTROLLER
  • Posted 13 Nov 2018 09:28
  • Reply by BREWSKI
