Trouble code C8-1
Hello...can anyone tell me what a code C8-1 would be on a this Toyota 7FBEU20 S/N 10909? Also, possibly email me a diagnostic test procedure to repair this problem? It acts like the left motor brake does not release then will release and work fine until you take your foot off the accelerator.
Any help would be much appreciated.
  • Posted 14 Oct 2015 02:11
  • By Gump
  • joined 10 Jun'11 - 30 messages
  • Iowa, United States
Check under the lift the wire sometimes cuts
And give wrong diagnostic have to replace speed sensor and still same controller.. same problem until trace the wire is ligh blue and is broken reconnect and all is working perfect..
  • Posted 17 Feb 2025 14:44
  • By armando_g
  • joined 11 May'18 - 48 messages
grgarryciencia@aol.com
Thank you! I appreciate your help.
  • Posted 30 Oct 2015 03:22
  • By Gump
hello, just seen you responded sorry for the late re post, on the drive motor you will see a small two wire plug, ohm the wiring from that plug to the drive controller , located on the back left side panel if you are sitting on the truck, if wires are okay, you can swap the controllers from the top to bottom, if code the same you have a speed bearing issue
  • Posted 29 Oct 2015 10:42
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
Thank you for your response...is there a way one can test to see which is failing? Like the bearing or if the signal is lost? How would one identify which issue is causing the problem?
  • Posted 14 Oct 2015 13:32
  • By Gump
Output when the traveling AC driver 1 detects the abnormality of the drive motor 1 rpm sensor. basically you have a drive motor sensor bearing failing on you or your losing the signal to the drive amplifier. common issue we see with these trucks.
  • Posted 14 Oct 2015 13:17
  • By fixnproblems
SMV (Konecranes) SL37-1200A
Tusk 350CGH20
