travel problem, no forward,slow reverse
i have pulled the curtis1215 controller and interface to be tested but i have no info on speed pot wiring(3 wire) as to how it works. it turns cw or ccw from neutral, f and r contactors close with micro switch selection and controller shows no codes.
  • Posted 15 Nov 2010 03:23
  • By bill_n
  • joined 15 Nov'10 - 1 message
  • Illinois, United States
it takes what it takes
Does your serial number start with...b815? If so...after centering the pot...you'll have to calibrate the main interface board...
I've also had problems with the wiring...i've soldered the wires staight from the pot to the harness...bypassing the 3 wire connecter...a number of times
  • Posted 23 Nov 2010 12:42
  • By ryalsh
  • joined 23 Nov'10 - 1 message
Maxlion MTF25-60-2WD
Terberg YT223
Terberg YT223
