Transmission trouble
Hi I'm new here and desperately looking for help with my forklift.
It's an automatic transmission. Works fine on flat surface but when a slight incline Comes it just pops into neutral.
The clutch seems to be ok because when I get a run at the hill the engine comes under pressure. I have removed the inching cylinder to see was that causing the problem and still the same when it was off.
If anyone can shed some light on my problem it would be greatly appreciated
  • Posted 15 Jun 2020 06:41
  • By Billyb
  • joined 15 Jun'20 - 1 message
  • Ireland
Does this occur in both forward and reverse going up a hill?
  • Posted 7 Jan 2021 15:38
  • By charlie_j
  • joined 5 Nov'04 - 46 messages
Take time to do the job right the first time, or you will have to make time to do the job over
Noblelift
Noblelift
