Transmission prob
Have a Cat GP/30,takes a long time for it change from forward to reverse and from low to high.
  • Posted 23 Aug 2011 09:41
  • By trailers5
  • joined 23 Aug'11 - 2 messages
  • Washington, United States
check your inching valve springs for breakage
  • Posted 13 Sep 2011 07:06
  • By TIMBO
  • joined 7 Jun'11 - 19 messages
My bet since it is in all functions go with the easy check first in the inching system. If all is ok there start a the pump pressure.
  • Posted 24 Aug 2011 03:22
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
and eyeball the inching lever linkage to make sure it it free and allowing proper travel of the inching valve spool
  • Posted 23 Aug 2011 21:23
  • Modified 23 Aug 2011 21:23 by poster
There should be a total of 5 different readings: main pressure, torque converter inlet pressure, torque converter outlet pressure, clutch pressure, and lube oil pressure. All are tested by using ports on the valve body.
  • Posted 23 Aug 2011 10:08
  • By certifiedtech
  • joined 5 Aug'10 - 39 messages
You talking about a pressure reading off the pump?
  • Posted 23 Aug 2011 09:53
  • By trailers5
What are the pressure readings? could be misadjusted linkage, slipping clutch, bad pump, etc. Without pressure reading it just a guess
  • Posted 23 Aug 2011 09:48
  • By certifiedtech
Maxlion FD50T
Enforcer FLBAXT25
Maxlion FD50T
Enforcer FLBAXT25
