TRANSMISSION OIL COMMING OUR OF BREATHER
Hi....
We overhauled 2 clark transmission , oil is comming our of the breather ,we have replaced,breather, torque, plates, seals.any thing to do with inching pedal...... bit confused
  • Posted 22 Apr 2010 17:51
  • By allan_l
  • joined 24 Sep'07 - 32 messages
  • united arab emirates, United Arab Emirates
yeah but what happens if we overfill, we have another same 3 ton clark forklift and transmission level is over but oil not coming from breather, and the other same forklift 3 ton clark when we'll fill little over start coming from breather.please advise
  • Posted 16 Jul 2014 19:47
  • By rimmi786
  • joined 25 Mar'14 - 3 messages
  • uae, United Arab Emirates
rimmi786
AND YOU CHECK IT THE OIL LEVEL WITH THE ENGINE...........? RUNNING OR NOT.....
WITH THE OIL TEMP AT ____C?
MAY BE, YOU ARE SOME CONFUSED.....
ALSO NEED TO KNOW THE MODEL AND SERIAL NUMBER..... ONLY FOR KNOW WHAT TRANSMISSION IS???
  • Posted 12 Apr 2014 12:47
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
  • Posted 12 Apr 2014 12:45
  • By raul_s
no sir ATF is perfectly ok just like a new and level also ok, when we do work too much then oil coming from the breather, and we have install new transmission pump also and hydraulic pump also good no hyd pump seal leak. now could you plz advise...
  • Posted 25 Mar 2014 22:40
  • By rimmi786
rimmi786
Does the oil look foamy? Could be pulling in air at the pump
  • Posted 25 Mar 2014 21:40
  • Modified 25 Mar 2014 21:40 by poster
  • By bbforks
hello allan can you plz contact me i'm also livinf in dubai and facing the same problem in my clark forlift. my number is 00971504567934
just gimme a miscall i'll contact u muself, or any body could assist me in this regards will be appreciate and thnkful.
  • Posted 25 Mar 2014 17:29
  • By rimmi786
rimmi786
hi... oil is as per dip stick level looks ok...wht could be the other reasons ,when it becomes hot more oil comes out
  • Posted 23 Apr 2010 12:52
  • By allan_l
How much oil did you put in the transmission???? maybe overfilled.
  • Posted 22 Apr 2010 22:10
  • By Prentice
Oxford Ct, United States
Esie Cortez Esie Cortez
