transmission issue
yale gdp090lg transmission starts slipping after 30 minutes of use. seems to have a short also blows the diode on 2nd speed valve harness
Yale GDP090LGNJBE098 Serial B813D03790V 1998
  • Posted 24 May 2022 14:20
  • By Al_Gonzalez
  • joined 24 May'22 - 1 message
I would suspect a short to ground in the harness due to the age. Since it is running for thirty minutes before slipping, bad fluid, seal or Oring. The wire harness if I remember correctly is all orange wires. Does the diode fail when key is first turned on or when the transmission starts slipping?
  • Posted 27 May 2022 08:06
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
