Transmission help
Hi I have pulled a transmission out a tcm and replaced clutch basket all plates all new seals and orings new tourqe convertor and pump
Truck ran perfect for 4 months then had an issue where drive engagement forward was slow once in its fine. If reverse is selected then forward it takes a while to engage reverse is perfect
If you just select forward then neutral its also perfect
Stripped all Spools out the block and replaced with new including springs still I have the issue
I'm running out of ideas but have just ordered new valve block incase a spool is sticking due to age/wear in block is there anything else anyone can think off I've missed
Thanks
  • Posted 12 May 2021 06:17
  • By Tech1
  • joined 12 May'21 - 1 message
  • Warwickshire, United Kingdom
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
UN Forklift FB25N1LZ1
Terberg RT403
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
