TRANSMISSION FLUID LEAKING
TRANSMISSION FLUID IS LEAKING (SHOOTING OUT) FROM UPPER PART OF TRANSMISSION CASING NEAR THE OIL FILTER (RIGHT BELOW) AFTER RUNNING IT FOR 1 1/2 TO 2 HOURS WHEN THE OIL IS HOT. IT COMES OUT WHEN ITS MOVING SO I CAN'T SEE EXACTLY WHERE ITS COMING FROM.
  • Posted 15 Apr 2021 14:28
  • By DAN_TELDESCHI
  • joined 15 Apr'21 - 1 message
DAN TELDESCHI
Safely raise both drive wheels off the ground, and then you will be able to observe it while it's operating. Have a few cans of brake cleaner on hand. Before you running it spray the entire area down with brake cleaner. Only doing it when it's hot makes me think gasket, o-ring, or seal. There are only a few places it can be coming from. They are valve body, valve body gasket, oil filter, trans coolant hose, trans coolant nipple ( there is an o-ring on it). Worse case scenario would be a cracked housing. Good luck, if I think of anything else I will let you know
  • Posted 15 Apr 2021 23:20
  • By Ddoyle
  • joined 18 Jun'18 - 3 messages
Taylor TX175
New - Sale & Hire
Enforcer FD50T-MMA
