trans code 20-60
Have trans problem..Unit will move five feet. I don't have serial number.Than trans locks out and throwes code 20-60.Which I think is trans pressure but not sure.Does anyone have any ideas this.Also what is the trans pressure and where to hook up mechanical guage to trans.Please let me know.
thanks
ED
  • Posted 17 Mar 2013 11:27
  • By tool_king
  • joined 1 Jun'10 - 21 messages
  • New Jersey, United States
Thank you for the information on this problem.How is the calibration done ?With a scan tool or just with unit controls?
thanks
ED
  • Posted 18 Mar 2013 11:35
  • By tool_king
This is for a Dana TE13000-17000.
The pump pressure should be 25-30bar and is checked at the port on the top of the transmission at the bell housing end, second in from the left looking towards the engine. Sensor is plug and play and error will clear when fault is repaired, there is a calibration that should be done after sensors are replaced on the transmission but it will work fine without carrying this out.
Steve.
  • Posted 18 Mar 2013 04:56
  • By steven_w
  • joined 20 Oct'06 - 16 messages
  • Aberdeenshire, United Kingdom
Thank you Steven.Do you know were to put a pressure guage into trans case to make sure trans has pressure ? There are several port plugs on trans.Also do you a scanner to clear code after sensor is replaced? Would you happen to have a service manual and parts manual in pdf form for this forklift?
thanks
Ed
  • Posted 18 Mar 2013 01:21
  • Modified 18 Mar 2013 01:23 by poster
  • By tool_king
Hi Ed, you are correct, the error relates to the transmission pressure as the sensor is reporting there is no pressure when there should be. It is most likely to be the sensor itself, it is the purple sensor behind the cover with the multi-plug.
Steve.
  • Posted 17 Mar 2013 20:24
  • By steven_w
Aichi SR18A
Maxlion FDR45
