Trans brake limited , intermittent 522157-2 fault showing.
522157-2 I've got a manual for this code. It states DTC 522157-2 - TISS Sensor Direction or Direction Check Input Failure (TCU).
gone to the live data for the Xmsn and the input sensor rpm is reading correctly. the match the rpm on the engine.
Anyone know what else could cause this fault and how to test.
the display also show 'trans brake limited use brake' message when at high speed then disappears when you come to a stop.
any info would be appreciated.
  • Posted 2 Oct 2020 20:12
  • By Garry_Bennett
  • joined 2 Oct'20 - 3 messages
  • Manchester, United Kingdom
GBennett
I've already set this up 0 degree using on live read out on the dash. Also calibrated the xmsn valve using the dashboard. Still no change
  • Posted 23 Oct 2020 01:25
  • By Garry_Bennett
GBennett
The trans brake issue is normally due to the adjustment of the inching pedal. The pedal sensor is not adjusted correctly. This may remove the tiss code.
  • Posted 22 Oct 2020 23:50
  • By fltandy
  • joined 10 Dec'14 - 5 messages
  • CHESHIRE, United Kingdom
They've both been changed already. No change in codes. When it does fault trans brake limited ,use brake message shows.
  • Posted 17 Oct 2020 08:24
  • By Garry_Bennett
GBennett
pls kindly change both the tiss and toss sensors and see....thanks
  • Posted 17 Oct 2020 04:34
  • By northstar
  • joined 16 Jun'17 - 92 messages
  • accra, Ghana
pls check the tiss sensor....thanks
  • Posted 17 Oct 2020 04:31
  • By northstar
  • accra, Ghana
A lot of the times when you get a TISS or TOSS code the other sensor can be the actual problem. I've learned this from experience.
  • Posted 17 Oct 2020 04:19
  • By LCNIII
  • joined 17 Oct'20 - 8 messages
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 02-8FD30
Stu Jacover Stu Jacover
Chief executive officer, TVH
