Toyota Forklift 5 FBE 18 error FR or FA
Hi,
My forklift is showing an error FR or FA I am not sure what is the second letter, noting that the hydraulic pumps are working.
Regards
  • Posted 26 Feb 2010 02:04
  • Discussion started by Alain_S
  • Quebec, Canada
Check resistor and wiring under battery tray.known for acid build up and corrosion
  • Posted 25 Sep 2021 00:39
  • Reply by roc109
Thank you
The resistor's connector was corroded.
If you have the error codes list, I would appreciate if you can send me a copy
  • Posted 27 Feb 2010 05:40
  • Reply by Alain_S
  • Quebec, Canada
resistor is under battery
  • Posted 26 Feb 2010 09:06
  • Reply by rich_k
Thank you Robert,
I will check it and let you know
  • Posted 26 Feb 2010 04:09
  • Reply by Alain_S
  • Quebec, Canada
Not that familiar with this Toyota, but I don't think there is an FR code. The FA code refers to the RAD, Resistor Absorber. Should be a resistor pack and it should measure 1.5 ohms.
  • Posted 26 Feb 2010 03:53
  • Reply by Robert
  • United States
Flight Systems Industrial Products
717-254-3747
GE/Curtis Authorized Repair Facility
WWW.FSIP.BIZ
