Toyota 8FGU25 fault codes
I am working on an LPG unit (which was running) that at first had two fault codes along with a check engine light, they were 03-1 and 05-2, related to intake pipe pressure sensor and throttle position sensor respectably. While troubleshooting them a third code appeared, Ad-1, and the unit now will not start. That seems to be related with the "CAN communication 4Y-ECS data reception". The low fuel alarm is also ring incessantly now, although there is ample fuel supply. Any ideas on where to look will be greatly appreciated. Thanks in advance!
  • Posted 11 Feb 2016 09:52
  • Discussion started by DaveSr
Which harness? I have the same issue
  • Posted 22 Jun 2021 05:36
  • Reply by jonathanburrows
  • Michigan, United States
Turned out to be a bad wire harness.
  • Posted 11 Mar 2016 09:26
  • Reply by DaveSr
03-1 Blinking 4Y-ECS Intake pipe pressure sensor open abnormality - The engine may have a problem
05-2 05-2 Blinking 4Y-ECS Throttle position sensor 1 short abnormality - Limting speed of traveling and materials
handling due to limited engine power
  • Posted 11 Mar 2016 07:09
  • Reply by elton_s
  • Sao Paulo, Brazil
Taylor TT300
Ncn 85TH
Ncn 85TH 2017
Zhejiang UN Forklift Co., Ltd
edition #1235 - 19 June 2025
