Just want to tell you when you take out the check valve make sure you put it in the same direction the big hole should be facing you it can go in wrong it will not lift correctly if in backwards
At the bottom of the rod held in by a snap ring. Should be able to be pulled out with a pick and slight tension.
Is the check valve inside the cylinder, any tips on removing it
Free lift cylinder bottom seal is more than likely cracked. Definitely repack and replace the bullet valve at the bottom.
The free lift packing is probably bad and there is a check valve in the bottom of the piston you have to replace it or it will not cycle correctly. Hope l was of help.
