Toyota 7hbw23 etac card
I am having a problem with a toyota 7hbw23. The original problem was that the key pad would not power up (no light when buttons were pushed). I checked and found that the etac card was bad. When I put the new card in and plugged in the battery the display instantly says test. I have replaced many of these cards and never had this happen, and there is nothing in the manual about it. Has anyone ever seen this?
  • Posted 24 Oct 2012 09:01
  • By certifiedtech
  • joined 5 Aug'10 - 39 messages
You need BT / Toyota TruckCom software + the correct firmware package for the truck OR order the correct card with the firmware already installed, you would then need a BT / Toyota CAN service key to change the default parameter settings.
You can always call BT / Toyota out to install the software & set the parameters but it will cost.
  • Posted 24 Oct 2012 20:15
  • By Forkingabout
  • england, United Kingdom
How does one go about installing the firmware on the card? I've got a card that went down with the same problem as the OP and hoping that reinstalling the firmware will correct it.
  • Posted 24 Oct 2012 15:17
  • By sleepywheel
  • joined 18 Jan'08 - 77 messages
  • British Columbia, Canada
The new etac cards need to have the firmware put on them. They come from the factory blank now.
  • Posted 24 Oct 2012 12:40
  • By rogeriwt
Kalmar-Ac P100CXD
TCM FHD105Z
Muncie, IN, United States
