TOYOTA 7FBEF20/7FBEU20 Error Code C1-4
I found out that an error code c1-4 on my TOYOTA 7FBEF/EU20 3 wheeler.
When I refer to the operation manual, I found out that it is the DCR_RH traveling AC driver 2 overcurrent.
I have no idea what to do with it.
I sincerely hope you guys could help it out. Please kindly send me a guide via my email address in the signature below.
Thanks
  • Posted 25 Aug 2016 13:38
  • By adrian_o
  • joined 25 Aug'16 - 1 message
adrian7386@gmail.com
You need to make sure your drive motor cables are not shorted. Check the under carriage of the machine and see if drive motor cables are not dragging on the ground. Pull battery out and make sure acid corrosion did not dissolve the insulation off the cables. If there okay, unplug the battery for 5 minutes cycle the key and see if your code returns,if so you have a failed drive controller. If you need to test for sure. the controllers can be swapped.
  • Posted 31 Aug 2016 10:50
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
edition #1264 - 15 January 2026
In this week’s Forkliftaction News , we look at the top five robotics trends forecast for 2026 from the International Federation of Robotics, and it’s an eye-opening read with the potential for robotics, AI and automation to work together to change our sector in fundamental ways... Continue reading
Australia was the first nation to successfully convert its paper-based currency to polymer banknotes, a technology developed in the same country. The first polymer banknote was a commemorative $10 note issued in 1988 to mark the Bicentenary. The first polymer banknotes were also the first to feature a transparent "window" as a security feature.
GemOne
Arnold, MO, United States
Claire Grossmann Claire Grossmann
Secretary general , FEM - European Materials Handling Federation
Chief revenue officer, Corvus Robotics
EVP corporate affairs & brand, Konecranes
Senior vice president, Crown Equipment
