Toyota 5FB10
I have a problem with the lifting.
F & R and lifting work fine but as soon I try to use both at the same time lifting is out of service and F & R works well.
Your comments and technical information will be appreciated
  • Posted 21 Feb 2006 21:13
  • By manuel_m
  • joined 29 Sep'05 - 7 messages
  • Sevilla, Spain
that is correct sir
  • Posted 19 May 2006 09:35
  • By steponmebbbboom
non marking are the white tires
black rubber tires are the same as having a static strap even if just on the steer axle
  • Posted 15 May 2006 06:47
  • By justinm
does this truck have non-marking tires? If it does, it has to have a static strap installed. Otherwise transient static electricity will build up and cause problems with the electronics.
  • Posted 15 May 2006 02:24
Have sent you the codes by email, any problems please contact me.
  • Posted 27 Feb 2006 18:13
  • By adrian_w
  • joined 18 Nov'05 - 33 messages
  • East Yorkshire, United Kingdom
Premier Mechanical Handling,
Hull.
UK
Thank you Manuel, i have passed your email address on to Adrian W
  • Posted 24 Feb 2006 20:44
  • By Admin
  • joined 18 May'04 - 266 messages
  • Queensland, Australia
I think you have to ask admin to pass on your email address.
  • Posted 24 Feb 2006 07:16
  • By adrian_w
Hull.
UK
Thanks for your quick answer adrian.
Could you please give me these codes?. How can I contact with you?
  • Posted 22 Feb 2006 19:14
  • By manuel_m
  • Sevilla, Spain
Easy.
The machine is in demo mode and requires pograming up through the head unit. Some times the head stock computer goes faulty and reverts back to its pre delivery status.
I have the setup codes if required.
  • Posted 22 Feb 2006 05:25
  • By adrian_w
Hull.
UK
