Toyota 18k LP model/THDC1800-36/ 2019/ serial 100367
Having issues with the lifting system on this forklift. I can hit the clutch pedal and function the lift lever and it'll go up just slightly then stop. Same with tilt, or fork separator. Will not lower at all no matter the sequence. Unit is stuck in air 2 ft and would like any input to try to get this moving again. Thanks in advance.
  • Posted 13 Aug 2025 00:17
  • By Jesse_Butler
  • joined 13 Aug'25 - 1 message
  • VA, United States
Jesse butler
No errors on display? Does it drive? Seat belt switch, seat switch , mast height switch, tilt switch,
Tilt angle sensor? Fuses for functions and or if it has sas?
Steering operate?
  • Posted 13 Aug 2025 14:38
  • By ron_k
  • joined 2 Apr'15 - 149 messages
  • North Dakota, United States
4kliftman
