I'm having an issue where the tilt function doesn't work at times. when it does the wrench will eliminate and code 67-1 appears. This code and the wrench light goes off when you work the tilt back and forth. The tilt seams to have a bind where the idle will drop like it has to work hard to get it to tilt. If I move the tilt back and forth it will release and work properly, after it sits it has the same issue. really confused. Thanks
