Tilt Drift
Tilt drifts with truck running or not
Blocked off tilt cylinders to rule out packing
Can't find any visable problem in the electronic control valve
Any idea where to look?
  • Posted 8 Jan 2011 00:59
  • By catlift1
  • joined 8 Jan'11 - 1 message
  • Illinois, United States
I think there are three possibilities.
1. There is a counterbalance valve built into the tilt valve spool. Could be broke, scored or contaminated. The spring could also be broke.
2. The tilt spool is damaged.
3. Once of the spool centering springs is broke.
1&2 and the top spring can be easily done in the truck. But I can't remember how easy it is to get to the bottom spring with the valve in the truck.
ISZ
  • Posted 9 Jan 2011 15:01
  • By icestationzebra
  • joined 1 Sep'08 - 12 messages
  • Wisconsin, United States
Lift Tek Elecar
