Lifting sequence problem
We have a Hyster 60. This fork lift came from government surplus and the plate with the model number was removed, so I don't have that info.
The problem is when lifting the second stage lifts first.
Just for clarity, the first stage is lifted by a single cylinder until it reaches the top of the uprights, then the second stage begins lifting by two cylinders.
I have not been able to figure out what switches the hydraulics from the first stage to the second stage. I don't see any switches or valves on the uprights that sense the position of the first stage to cause the change.
So my question is what causes the change from fist to second stage lift? If anybody has any idea what is causing this problem, please let me know.
Thanks Glen
  • Posted 31 Mar 2017 19:44
  • By glen_h
  • joined 31 Mar'17 - 3 messages
  • Hawaii, United States
The valve is in the piston assy at the bottom of the ram (chrome part the extends out when forks raised). The only way to service the valve is to remove the entire cyl from the machine & disassemble the cyl. Any competent hydraulic shop should be able to replace the valve for you.
  • Posted 25 Apr 2017 23:58
  • By bbforks
That is what happens. When the second stage reaches the top the first stage then starts to raise.
I found the data plate for the mast. The model number is SS33.00-4.50 1219-1356883 The serial number is B603 (printed) B352.1 (stamped)
I was looking for the flow valve, I don't see any vale at the bottom of the first stage cylinder. I do see plumbing that goes to a box on the fire wall (for lack of a better name) and there are two lines that go to the two second stage cylinders. Could this be the location of the flow valve?
Thanks for your help.
  • Posted 6 Apr 2017 16:33
  • By glen_h
if you lift all the way up until the stage bottoms and then the carriage goes up then I would definitely look at replacing the flow valve in the bottom of the free lift piston
  • Posted 6 Apr 2017 10:04
  • By vashxj
  • joined 6 Apr'17 - 4 messages
  • illinois, -
Thank you very much for the reply. I will look into the check valve. There is a data plate for the mast still in place.
Glen
  • Posted 1 Apr 2017 06:56
  • By glen_h
There is a check valve in the base of the free lift cylinder ram. Usually miss staging is caused by this check valve. You will need the mast model and serial number to get the correct parts. There should be a serial number stamped in the frame for the truck. The mast numbers are stamped on the stationary rail.
  • Posted 31 Mar 2017 23:40
  • Modified 31 Mar 2017 23:42 by poster
  • By BREWSKI
Sue Tomic Sue Tomic
SMV (Konecranes) SL37-1200A
SMV (Konecranes) 4632CC5
